Compaq Evo N1000v Keyboard Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
98
All Time:
4,336
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Among all the parts of your Compaq Evo N1000v, the keyboard could be one of the most utilized parts, which might have a tendency to wear out or malfunction or completely die out after some time. In many cases, the laptop keyboard does not have to be physically damaged; some keys do not work or deteriorate on the whole before you know it is time to replace it for a smooth user experience. A new keyboard will offer responsiveness and comfort while typing, adding to the overall longevity of your laptop. This guide will walk you through replacing the keyboard in your Compaq Evo N1000v, making your laptop feel like new again and reliable for everyday use.
Before you begin this repair, make sure that your laptop is off and disconnected from the charger.
Tools
  • Spudger
    4.9
  • TR8 Torx Security Screwdriver
    4.9
    1. Compaq Evo N1000v Keyboard Replacement, LED Cover: step 1, image 1 of 1
      • Flip the laptop over with the rear panel facing forward.
      Ask FixBot
    2. Compaq Evo N1000v Keyboard Replacement: step 2, image 1 of 1
      • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
      Ask FixBot
    3. Compaq Evo N1000v Keyboard Replacement: step 3, image 1 of 1
      • Flip the laptop back over with the front facing forward. Open the screen.
      Ask FixBot
    4. Compaq Evo N1000v Keyboard Replacement: step 4, image 1 of 1
      • Locate the F1 and F2 keys near the top left corner of the keyboard.
      Ask FixBot
    5. Compaq Evo N1000v Keyboard Replacement: step 5, image 1 of 1
      • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      Ask FixBot
    6. Compaq Evo N1000v Keyboard Replacement: step 6, image 1 of 1
      • Locate the Scroll and Pause keys near the top right corner of the keyboard.
      Ask FixBot
    7. Compaq Evo N1000v Keyboard Replacement: step 7, image 1 of 1
      • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      Ask FixBot
    8. Compaq Evo N1000v Keyboard Replacement: step 8, image 1 of 2 Compaq Evo N1000v Keyboard Replacement: step 8, image 2 of 2
      • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
      Ask FixBot
    1. Compaq Evo N1000v Keyboard Replacement, Keyboard: step 9, image 1 of 1
      • Lift the back edge of the keyboard and pull towards the screen.
      Ask FixBot
    2. Compaq Evo N1000v Keyboard Replacement: step 10, image 1 of 1
      • Pull the cable and lift up to release.
      Ask FixBot
    3. Compaq Evo N1000v Keyboard Replacement: step 11, image 1 of 1
      • Remove the keyboard.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
kim
77 Reputation
3 Guides authored
Cal Poly, Team 29-74, Johann Spring 2010 Member of Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 98
All Time: 4,336
