Up to 20% off select tools
Compact Fluorescent Lightbulb CFL Lightbulb Replacement
Views: 9.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
22
Past 30 Days:
111
All Time:
9,406
Comments: 1
1 guide comment.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 17
17 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
The CFL lightbulb has taken over in today's suburban home. Using less than 30 watts to power it and having the same light output as a standard 100 watt incandescent bulb, the CFL is certainly a "bright idea".
    1. Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: step 1, image 1 of 2 Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: step 1, image 2 of 2
      • Locate the bad bulb and remove it from the socket. This is achieved by grabbing the bulb lightly and rotating counter-clockwise.
      • The bulb may be hot. If so, use gloves, or wait for it to cool.
      Ask FixBot
    2. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: step 2, image 1 of 1
      • Procure a new lightbulb, either from a hardware store, or wherever it is you keep new ones.
      • Install the new lightbulb into the socket, this time rotating clockwise.
      • Be sure the power to the socket is turned off before you preform this step. Failure to do so my cause injury.
      Ask FixBot
    3. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: step 3, image 1 of 1
      • Turn the power on to the light socket by means of a switch or knob.
      • Congratulations! You have successfully changed a lightbulb! Reward your efforts by getting a cold beverage of your choice.
      Ask FixBot
Finish Line
12 other people completed this guide.
Author
with
WiseGeek
1,364 Reputation
2 Guides authored
1 Guide Comment
You shouldn't unscrew/screw CFL Bulb from its tube because there is a very small risk that it will break (Especially if it has the tubular shape (2U, 3U and 4U)). Try to unscrew/screwing it from its plastic base.
Jokid - Reply Share
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 111
All Time: 9,406
