Up to 20% off select tools
Commodore 64 Removing the Shift-Lock Key
Views: 3.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
109
All Time:
3,367
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The Commodore 64, also known as the C64, C-64, C=64, or occasionally CBM 64 or VIC-64, is an 8-bit home computer introduced in January 1982 by Commodore International.
    1. Commodore 64 Removing the Shift-Lock Key, Removing the screws: step 1, image 1 of 3 Commodore 64 Removing the Shift-Lock Key, Removing the screws: step 1, image 2 of 3 Commodore 64 Removing the Shift-Lock Key, Removing the screws: step 1, image 3 of 3
      • 1. Remove three 6.75mm ph2 screw heads from the casing.
      Ask FixBot
    2. Commodore 64 Removing the Shift-Lock Key, Opening the Case: step 2, image 1 of 1
      • 2. Split the case of the C64 open by pulling up on the case towards you
      • Do not pull too hard that you break the clips.
      Ask FixBot
    3. Commodore 64 Removing the Shift-Lock Key, Removing screws (continued): step 3, image 1 of 1
      • 3. Remove eight 6.75 mm ph2 screw heads to detach the keyboard face from the front casing. (Two remaining screws on the right side.)
      Ask FixBot
    4. Commodore 64 Removing the Shift-Lock Key, Removing Screws (continued): step 4, image 1 of 1
      • 4. Remove twenty-three 3.38 mm ph2 screw heads from the back of the keyboard facing
      Ask FixBot
    5. Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: step 5, image 1 of 3 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: step 5, image 2 of 3 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: step 5, image 3 of 3
      • 5. Detach the multi-colored wire bundles connected to the motherboard
      Ask FixBot
    6. Commodore 64 Removing the Shift-Lock Key, Cutting the Wires: step 6, image 1 of 1
      • 6. Next, carefully cut the two small wires which are connected from the Shift/Lock key to the keyboard.
      Ask FixBot
    7. Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: step 7, image 1 of 2 Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: step 7, image 2 of 2
      • 7. Turn the keyboard down on its face and push the shift lock key out from the back of the keyboard.
      Ask FixBot
    8. Commodore 64 Removing the Shift-Lock Key, Removal of circuit component from shift-lock key (optional): step 8, image 1 of 1
      • 8. You can remove the circuit component (gray piece attached to the shift lock key spring) by pulling back slightly on its clip and pulling it apart from the shift lock key button.
      • * Take off the shift key button from the spring by using any Philips screwdriver to pry it off from the spring.
      Ask FixBot
5 other people completed this guide.
Author
with
Silvanus Clarke
677 Reputation
5 Guides authored
USF Tampa, Team 13-6, Staggers Fall 2014 Member of USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Members
60 Guides authored
1 Guide Comment
You should desoder the shift lock wires. Not cut them :(
Darek Greenly - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 109
All Time: 3,367
