Up to 20% off select tools
Commodore 64 Opening the Case Prerequisite Guide
Views: 7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
146
All Time:
7,034
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
The Commodore 64, also known as the C64, C-64, C= 64, or occasionally CBM 64 or VIC-64, is an 8-bit home computer introduced in January 1982 by Commodore International.
    1. Commodore 64 Opening the Case Prerequisite Guide, Removing screws: step 1, image 1 of 3 Commodore 64 Opening the Case Prerequisite Guide, Removing screws: step 1, image 2 of 3 Commodore 64 Opening the Case Prerequisite Guide, Removing screws: step 1, image 3 of 3
      • 1. Remove three 6.75mm ph2 screw heads from the casing
      Ask FixBot
    2. Commodore 64 Opening the Case Prerequisite Guide, Opening: step 2, image 1 of 2 Commodore 64 Opening the Case Prerequisite Guide, Opening: step 2, image 2 of 2
      • 2. Split the case of the C64 open by pulling up on the case towards you
      • Do not pull too hard that you break the clips.
      Ask FixBot
8 other people completed this guide.
Author
with
Silvanus Clarke
677 Reputation
5 Guides authored
USF Tampa, Team 13-6, Staggers Fall 2014 Member of USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Members
60 Guides authored
1 Guide Comment
Is the Commodore 64x with the same screw?
anon - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 146
All Time: 7,034
