Up to 20% off select tools
Commodore 64 Central Processing Unit (CPU) Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
108
All Time:
3,766
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
The Central Processing Unit (CPU) or Micro Processing Unit (MPU) is the 8-bit processor for the Commodore 64.
    1. Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: step 1, image 1 of 3 Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: step 1, image 2 of 3 Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: step 1, image 3 of 3
      • 1. Remove three 6.75mm ph2 screw heads from the casing
      Ask FixBot
    2. Commodore 64 Central Processing Unit (CPU) Replacement, Opening: step 2, image 1 of 2 Commodore 64 Central Processing Unit (CPU) Replacement, Opening: step 2, image 2 of 2
      • 2. Split the case of the C64 open by pulling up on the case towards you
      • Do not pull too hard that you break the clips.
      Ask FixBot
    1. Commodore 64 Central Processing Unit (CPU) Replacement, Detach Keyboard from the motherboard: step 3, image 1 of 2 Commodore 64 Central Processing Unit (CPU) Replacement, Detach Keyboard from the motherboard: step 3, image 2 of 2
      • 1. Detach the multi-colored wire bundles connected to the motherboard.
      Ask FixBot
    2. Commodore 64 Central Processing Unit (CPU) Replacement, Locate the CPU: step 4, image 1 of 1
      • Locate the CPU chip which is labeled 'MOS 6510 3782'
      Ask FixBot
    3. Commodore 64 Central Processing Unit (CPU) Replacement, Removing the CPU chip: step 5, image 1 of 2 Commodore 64 Central Processing Unit (CPU) Replacement, Removing the CPU chip: step 5, image 2 of 2
      • 3. Loosen the CPU chip with a Phillips screwdriver. Then use your hand to pry up the CPU chip from the motherboard.
      Ask FixBot
5 other people completed this guide.
Author
with
Silvanus Clarke
677 Reputation
5 Guides authored
USF Tampa, Team 13-6, Staggers Fall 2014 Member of USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Members
60 Guides authored
1 Guide Comment
there are two problems
1. Use an spudger for lifting the C.P.U instead of an screw driver bit to help alleviate concerns of bending the pins,
2. There is an step missing which involves cutting the tape seen here.
- Jordan .F
Jordan Fryman - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 108
All Time: 3,766
