Up to 20% off select tools
Commodore 64 3AG fuse Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
8
Past 7 Days:
30
Past 30 Days:
137
All Time:
5,285
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Community-Contributed Guide
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
A 3AG fuse is a glass - bodied fuse designed to break an electric circuit if the current exceeds safety levels in a Commodore 64 device
    1. Commodore 64 3AG fuse Replacement, Removing screws: step 1, image 1 of 3 Commodore 64 3AG fuse Replacement, Removing screws: step 1, image 2 of 3 Commodore 64 3AG fuse Replacement, Removing screws: step 1, image 3 of 3
      • 1. Remove three 6.75mm ph2 screw heads from the casing
      Ask FixBot
    2. Commodore 64 3AG fuse Replacement, Opening: step 2, image 1 of 2 Commodore 64 3AG fuse Replacement, Opening: step 2, image 2 of 2
      • 2. Split the case of the C64 open by pulling up on the case towards you
      • Do not pull too hard that you break the clips.
      Ask FixBot
    1. Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: step 3, image 1 of 2 Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: step 3, image 2 of 2
      • 1. Detach the multi-colored wire bundles that's connected to the motherboard
      • In this picture, the power indication LED (connected to the black and red wires) is not fastened to the keyboard panel, yours might be different.
      Ask FixBot
    2. Commodore 64 3AG fuse Replacement, Locate 3AG fuse: step 4, image 1 of 1
      • 2. Find the 3AG fuse located next to the joystick ports and On/Off switch
      Ask FixBot
    3. Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: step 5, image 1 of 2 Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: step 5, image 2 of 2
      • 3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
      • * Replace the 3AG fuse by inserting the new fuse and letting it pop into the clip
      Ask FixBot
4 other people completed this guide.
Author
with
Silvanus Clarke
677 Reputation
5 Guides authored
USF Tampa, Team 13-6, Staggers Fall 2014 Member of USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Members
60 Guides authored
2 Guide Comments
The fuse is 1.5 Amp, not 3
JC Andy - Reply Share
3AG does NOT mean a fast acting fuse. It could be either fast or slow blow. The 3 means it's 1 1/4 " long, the "A" means it has Axial connections, and the "G" means it's made of glass.
Toon Konings - Reply Share
Past 24 Hours: 8
Past 7 Days: 30
Past 30 Days: 137
All Time: 5,285
