Comfort Zone CZ6C Switch Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
97
All Time:
2,997
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
Learn how to effectively replace the switch of your Comfort Zone CZ6C
Tools
    1. Comfort Zone CZ6C Switch Replacement, Switch: step 1, image 1 of 3 Comfort Zone CZ6C Switch Replacement, Switch: step 1, image 2 of 3 Comfort Zone CZ6C Switch Replacement, Switch: step 1, image 3 of 3
      • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
      • Before replacing your switch, learn how to solder using the How To Solder and Desolder Connections Guide.
      • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
      Ask FixBot
    2. Comfort Zone CZ6C Switch Replacement: step 2, image 1 of 2 Comfort Zone CZ6C Switch Replacement: step 2, image 2 of 2
      • Remove the plastic cover on the switch by pulling it apart from the the back panel.
      Ask FixBot
    3. Comfort Zone CZ6C Switch Replacement: step 3, image 1 of 1
      • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
      • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
      • Disconnect the gray power wire from the switch by desoldering the connection.
      Ask FixBot
    4. Comfort Zone CZ6C Switch Replacement: step 4, image 1 of 2 Comfort Zone CZ6C Switch Replacement: step 4, image 2 of 2
      • Cut the green and yellow wire as close to the switch connection as possible.
      Ask FixBot
    5. Comfort Zone CZ6C Switch Replacement: step 5, image 1 of 3 Comfort Zone CZ6C Switch Replacement: step 5, image 2 of 3 Comfort Zone CZ6C Switch Replacement: step 5, image 3 of 3
      • Strip the green and yellow wire about two centimeters from where it was just cut.
      Ask FixBot
    6. Comfort Zone CZ6C Switch Replacement: step 6, image 1 of 3 Comfort Zone CZ6C Switch Replacement: step 6, image 2 of 3 Comfort Zone CZ6C Switch Replacement: step 6, image 3 of 3
      • Unscrew the switch from the back panel and remove it.
      Ask FixBot
    7. Comfort Zone CZ6C Switch Replacement: step 7, image 1 of 3 Comfort Zone CZ6C Switch Replacement: step 7, image 2 of 3 Comfort Zone CZ6C Switch Replacement: step 7, image 3 of 3
      • After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
      Ask FixBot
James Abundis
169 Reputation
1 Guide authored
Cal Poly, Team 17-5, Forte Spring 2015 Member of Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Members
60 Guides authored
1 Guide Comment
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
Michael Drasic - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 97
All Time: 2,997
