Comfort Zone CZ6C Power Cable Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
89
All Time:
3,574
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
Learn how to properly replace the power cable of your Comfort Zone CZ6C.
Tools
    1. Comfort Zone CZ6C Power Cable Replacement, Power Cable: step 1, image 1 of 3 Comfort Zone CZ6C Power Cable Replacement, Power Cable: step 1, image 2 of 3 Comfort Zone CZ6C Power Cable Replacement, Power Cable: step 1, image 3 of 3
      • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
      • Before attempting to replace your power cable, learn how to solder using the How To Solder and Desolder Corrections Guide.
      • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
      Ask FixBot
    2. Comfort Zone CZ6C Power Cable Replacement: step 2, image 1 of 3 Comfort Zone CZ6C Power Cable Replacement: step 2, image 2 of 3 Comfort Zone CZ6C Power Cable Replacement: step 2, image 3 of 3
      • Unscrew the yellow cap that connects the black wire and the gray power cord wire. Then, unwind the tied wires and pull them apart.
      Ask FixBot
    3. Comfort Zone CZ6C Power Cable Replacement: step 3, image 1 of 2 Comfort Zone CZ6C Power Cable Replacement: step 3, image 2 of 2
      • Remove the plastic cover on the switch by pulling it apart from the back panel.
      Ask FixBot
    4. Comfort Zone CZ6C Power Cable Replacement: step 4, image 1 of 1
      • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
      • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
      • Disconnect the gray power wire from the switch by desoldering the connection.
      Ask FixBot
    5. Comfort Zone CZ6C Power Cable Replacement: step 5, image 1 of 1
      • Strip the end of the gray power cord.
      • Then solder the end of the gray power cord to the switch.
      Ask FixBot
Nishanth Dara
153 Reputation
1 Guide authored
Cal Poly, Team 17-5, Forte Spring 2015 Member of Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 89
All Time: 3,574
