Comfort Zone CZ6C Motor Replacement
Views: 6.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
107
All Time:
6,796
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Before replacing your fan's motor, use this Comfort Zone CZ6C Fan Blades Replacement Guide.
Tools
    1. Comfort Zone CZ6C Motor Replacement, Motor: step 1, image 1 of 3 Comfort Zone CZ6C Motor Replacement, Motor: step 1, image 2 of 3 Comfort Zone CZ6C Motor Replacement, Motor: step 1, image 3 of 3
      • Make sure to unplug the Comfort Zone CZ6C before replacing the motor. This will prevent the risk of electrocution.
      • Unscrew the main housing screw located right above the main switch using a Phillips screwdriver.
      • Then use gentle force to remove the main housing door.
      • Remember to keep track of your screws!
      Ask FixBot
    2. Comfort Zone CZ6C Motor Replacement: step 2, image 1 of 3 Comfort Zone CZ6C Motor Replacement: step 2, image 2 of 3 Comfort Zone CZ6C Motor Replacement: step 2, image 3 of 3
      • Unscrew the two adjacent housing screws to free the motor cage from the housing.
      Ask FixBot
    3. Comfort Zone CZ6C Motor Replacement: step 3, image 1 of 3 Comfort Zone CZ6C Motor Replacement: step 3, image 2 of 3 Comfort Zone CZ6C Motor Replacement: step 3, image 3 of 3
      • Remove the motor cage from the fan housing.
      Ask FixBot
    4. Comfort Zone CZ6C Motor Replacement: step 4, image 1 of 2 Comfort Zone CZ6C Motor Replacement: step 4, image 2 of 2
      • Unscrew the two adjacent motor cage screws to free the motor
      Ask FixBot
    5. Comfort Zone CZ6C Motor Replacement: step 5, image 1 of 3 Comfort Zone CZ6C Motor Replacement: step 5, image 2 of 3 Comfort Zone CZ6C Motor Replacement: step 5, image 3 of 3
      • The motor is now free to be replaced.
      • If the motor will not move out of its now freed state you can use WD-40 to loosen it
      Ask FixBot
5 other people completed this guide.
Gage Wilson
217 Reputation
1 Guide authored
Cal Poly, Team 17-5, Forte Spring 2015 Member of Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 107
All Time: 6,796
