Comfort Zone CZ6C Fan Blades Replacement
    1. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: step 1, image 1 of 3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: step 1, image 2 of 3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: step 1, image 3 of 3
      • The metal cage is kept in place by three plastic tabs on the plastic body. Focus your pulling around these tabs to make the job easier.
      • In order to remove the metal cage, place one hand firmly on the back plastic body and your other hand on the metal cage.
      • Now work your way around the edge of the fan cage and pull it away from the plastic body.
      Ask FixBot
    2. Comfort Zone CZ6C Fan Blades Replacement: step 2, image 1 of 2 Comfort Zone CZ6C Fan Blades Replacement: step 2, image 2 of 2
      • To remove the fan blade, reach behind it and slowly pull it towards you.
      • If the fan blade axle has any hair or dirt, then clean it with a cloth to avoid further fan blade blockage.
      • If you are having difficulty removing the fan blade, then generously apply WD-40 to the fan blade axle.
      Ask FixBot
Samantha Galicinao
289 Reputation
2 Guides authored
Cal Poly, Team 17-5, Forte Spring 2015 Member of Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Members
25 Guides authored
2 Guide Comments
Where does one buy the replacement blades?
Frank Gould - Reply Share
where does one buy the replacement blades??
Luis Marrero - Reply Share
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 60
All Time: 6,650
