ComNet Ericsson Panther 600P Speaker Replacement
  1. ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: step 1, image 1 of 3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: step 1, image 2 of 3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: step 1, image 3 of 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
    Ask FixBot
  2. ComNet Ericsson Panther 600P Speaker Replacement, Antenna: step 2, image 1 of 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
    Ask FixBot
  3. ComNet Ericsson Panther 600P Speaker Replacement, Dials: step 3, image 1 of 1
    • Pull up on the dials to remove them from the underlying pegs.
    Ask FixBot
  4. ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: step 4, image 1 of 3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: step 4, image 2 of 3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: step 4, image 3 of 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
    Ask FixBot
  5. ComNet Ericsson Panther 600P Speaker Replacement, Speaker: step 5, image 1 of 2 ComNet Ericsson Panther 600P Speaker Replacement, Speaker: step 5, image 2 of 2
    • Locate the device's speaker inside the front panel of the exterior case.
    • Locate the display and speaker stabilizer.
    • Lift the stabilizer up from the bottom and pull the stabilizer out of case.
    Ask FixBot
  6. ComNet Ericsson Panther 600P Speaker Replacement: step 6, image 1 of 3 ComNet Ericsson Panther 600P Speaker Replacement: step 6, image 2 of 3 ComNet Ericsson Panther 600P Speaker Replacement: step 6, image 3 of 3
    • Locate the two 3.75mm screws holding the speaker to the exterior case.
    • Using a T15 Torx screwdriver, unscrew the 3.75mm screws.
    Ask FixBot
  7. ComNet Ericsson Panther 600P Speaker Replacement: step 7, image 1 of 2 ComNet Ericsson Panther 600P Speaker Replacement: step 7, image 2 of 2
    • Lift up on the bottom of the speaker to detach the speaker.
    • Pull the speaker out of the case.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 26
All Time: 452
