ComNet Ericsson Panther 600P Motherboard Replacement
  1. ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: step 1, image 1 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: step 1, image 2 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: step 1, image 3 of 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
    Ask FixBot
  2. ComNet Ericsson Panther 600P Motherboard Replacement, Antenna: step 2, image 1 of 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
    Ask FixBot
  3. ComNet Ericsson Panther 600P Motherboard Replacement, Dials: step 3, image 1 of 1
    • Pull up on the dials to remove them from the underlying pegs.
    Ask FixBot
  4. ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: step 4, image 1 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: step 4, image 2 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: step 4, image 3 of 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
    Ask FixBot
  5. ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: step 5, image 1 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: step 5, image 2 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: step 5, image 3 of 3
    • Using the plastic opening tool, pry the case apart.
    Ask FixBot
  6. ComNet Ericsson Panther 600P Motherboard Replacement, Ribbon: step 6, image 1 of 2 ComNet Ericsson Panther 600P Motherboard Replacement, Ribbon: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • The keypad chip is attached to the motherboard by a ribbon.
    • Pull ribbon with tweezers to detach from back panel.
    Ask FixBot
  7. ComNet Ericsson Panther 600P Motherboard Replacement, Screen: step 7, image 1 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Screen: step 7, image 2 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Screen: step 7, image 3 of 3
    • Screen will be attached by a ribbon.
    • Pull screen up and away from motherboard to detach.
    Ask FixBot
  8. ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: step 8, image 1 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: step 8, image 2 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: step 8, image 3 of 3
    • Remove the rubber O-rings from the antenna jack, volume switch, and channel switch.
    • Once the rubber O-rings have been removed, use small needle nose pliers to unscrew the nuts on the antenna jack, volume switch, and channel switch.
    • There are washers underneath the nuts on the antenna jack, volume switch, and channel switch. Set these washers aside.
    Ask FixBot
  9. ComNet Ericsson Panther 600P Motherboard Replacement: step 9, image 1 of 1
    • Using a T15 Torx screwdriver, unscrew the 3.8mm screw from the case.
    Ask FixBot
  10. ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: step 10, image 1 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: step 10, image 2 of 3 ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: step 10, image 3 of 3
    • Using any convenient hand-placement, pull the motherboard away from the case.
    • The antenna jack, volume dial, and channel dial are attached to the motherboard. Be sure to pull the motherboard downward so they clear their respective slots in the case.
    • Lift the motherboard completely free of the case.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 26
All Time: 594
