ComNet Ericsson Panther 600P Display Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
94
All Time:
683
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
With a few tools, a little bit of time, and a moderate degree of commitment, you can replace a damaged display on ComNet Ericsson Panther 600P.
Tools
    1. ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: step 1, image 1 of 3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: step 1, image 2 of 3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: step 1, image 3 of 3
      • Look for the release button on the back of the radio.
      • Press the button and pull down on the battery at the same time. The battery will come free.
      Ask FixBot
    1. ComNet Ericsson Panther 600P Display Replacement, Antenna: step 2, image 1 of 1
      • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
      Ask FixBot
    2. ComNet Ericsson Panther 600P Display Replacement, Dials: step 3, image 1 of 1
      • Pull up on the dials to remove them from the underlying pegs.
      Ask FixBot
    3. ComNet Ericsson Panther 600P Display Replacement, Exterior Case: step 4, image 1 of 3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: step 4, image 2 of 3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: step 4, image 3 of 3
      • Using a T15 Torx screwdriver, unscrew the two screws.
      • Using a plastic opening tool, pry the internal case from the external case.
      Ask FixBot
    1. ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: step 5, image 1 of 3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: step 5, image 2 of 3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: step 5, image 3 of 3
      • Using the plastic opening tool, pry the case apart.
      Ask FixBot
    2. ComNet Ericsson Panther 600P Display Replacement, Ribbon: step 6, image 1 of 2 ComNet Ericsson Panther 600P Display Replacement, Ribbon: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • The keypad chip is attached to the motherboard by a ribbon.
      • Pull ribbon with tweezers to detach from back panel.
      Ask FixBot
    3. ComNet Ericsson Panther 600P Display Replacement, Screen: step 7, image 1 of 3 ComNet Ericsson Panther 600P Display Replacement, Screen: step 7, image 2 of 3 ComNet Ericsson Panther 600P Display Replacement, Screen: step 7, image 3 of 3
      • Screen will be attached by a ribbon.
      • Pull screen up and away from motherboard to detach.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 94
All Time: 683
