ComNet Ericsson Panther 600P Buttons Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
105
All Time:
753
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you press a button and the button does not move or if people cannot hear you talking while the talk button is pressed down, the buttons may need to be cleaned or replaced.
Tools
    1. ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: step 1, image 1 of 3 ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: step 1, image 2 of 3 ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: step 1, image 3 of 3
      • Look for the release button on the back of the radio.
      • Press the button and pull down on the battery at the same time. The battery will come free.
      Ask FixBot
    1. ComNet Ericsson Panther 600P Buttons Replacement, Antenna: step 2, image 1 of 1
      • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
      Ask FixBot
    2. ComNet Ericsson Panther 600P Buttons Replacement, Dials: step 3, image 1 of 1
      • Pull up on the dials to remove them from the underlying pegs.
      Ask FixBot
    3. ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: step 4, image 1 of 3 ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: step 4, image 2 of 3 ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: step 4, image 3 of 3
      • Using a T15 Torx screwdriver, unscrew the two screws.
      • Using a plastic opening tool, pry the internal case from the external case.
      Ask FixBot
    1. ComNet Ericsson Panther 600P Buttons Replacement, Remove Buttons: step 5, image 1 of 2 ComNet Ericsson Panther 600P Buttons Replacement, Remove Buttons: step 5, image 2 of 2
      • Grip the corner of the button pad and gently peal it away from the faceplate.
      • Clean off any sticky residue and/or replace the buttons.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 105
All Time: 753
