Up to 20% off select tools
ColecoVision Power Switch Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
88
All Time:
2,843
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Very difficult
Tools
Introduction
Go to step 1 ↓
The purpose of this guide is to communicate steps on how to replace or repair the power switch on a ColecoVision.
    1. ColecoVision Power Switch Replacement, Power Switch: step 1, image 1 of 1
      • Flip the ColecoVision over with the pegs facing the ceiling.
      • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
      Ask FixBot
    2. ColecoVision Power Switch Replacement: step 2, image 1 of 2 ColecoVision Power Switch Replacement: step 2, image 2 of 2
      • Carefully remove the bottom of the ColecoVision out of the top.
      • I would recommend running a metal spudger along the rim of the case to remove the bottom.
      Ask FixBot
    3. ColecoVision Power Switch Replacement: step 3, image 1 of 1
      • Remove the two 15 mm screws holding the casing in place using the Phillips #1 screwdriver.
      Ask FixBot
    4. ColecoVision Power Switch Replacement: step 4, image 1 of 2 ColecoVision Power Switch Replacement: step 4, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the two 15mm screws on the motherboard.
      • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
      Ask FixBot
    5. ColecoVision Power Switch Replacement: step 5, image 1 of 1
      • Flip the motherboard over.
      • Using a soldering iron, carefully desolder the power switch from the motherboard.
      • Refer to this soldering technique guide for reference.
      Ask FixBot
    6. ColecoVision Power Switch Replacement: step 6, image 1 of 1
      • Wait for power switch to cool down.
      • Turn the motherboard over upright.
      • Carefully lift up the power switch to completely remove it from the motherboard.
      Ask FixBot
Author
with
Bobby
380 Reputation
2 Guides authored
UW Tacoma, Team S1-G2, Rose Fall 2018 Member of UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 88
All Time: 2,843
