Up to 20% off select tools
Coin Counter Disassembly
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
127
All Time:
1,112
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Coin Counter Disassembly, Coin counter motherboard step 1: step 1, image 1 of 1
      • I will be showing you how to look at the motherboard of a coin counter
      • the first step is to flip it to the back to see the little screws
      Ask FixBot
    2. Coin Counter Disassembly, 2nd step for motherboard: step 2, image 1 of 2 Coin Counter Disassembly, 2nd step for motherboard: step 2, image 2 of 2
      • the second step is to remove the batteries.
      • To remove the batteries you have to take the top screw off
      • the second picture will show you how i toke out the screw in order to take out the batteries.to be safe when i get to the motherboard
      Ask FixBot
    3. Coin Counter Disassembly, 3rd step: step 3, image 1 of 3 Coin Counter Disassembly, 3rd step: step 3, image 2 of 3 Coin Counter Disassembly, 3rd step: step 3, image 3 of 3
      • the third step is to take out the 3 little screws in which side of the circle
      • In total you should have 3 screws. make sure you don"t lose them in case you want to put it back together
      Ask FixBot
    4. Coin Counter Disassembly, 4th step: step 4, image 1 of 2 Coin Counter Disassembly, 4th step: step 4, image 2 of 2
      • The fourth step is to remove the othere crews from the motherboard. You need to remove the crews in order to take out the motherboard.
      • You have to have the 4 screws if your switch the motherboard to a other one.
      Ask FixBot
    5. Coin Counter Disassembly, 5th step: step 5, image 1 of 2 Coin Counter Disassembly, 5th step: step 5, image 2 of 2
      • The 5th step is the hardest part because you have to now remove the red and black wires from both sides so then you can see the motherboard.
      • Be very careful removing or pulling the wires because it can break the other wires which will not work anymore.
      Ask FixBot
    6. Coin Counter Disassembly, last step: step 6, image 1 of 1
      • The last step is you got to the motherboard which was my goal. you could use the motherboard for other projects or just put it back for more a challenge.
      • My decisions was to put it back together, so then i can have more of a challenge. thank you for your time and i hoped this helped
      Ask FixBot
Author
with
osmar
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 127
All Time: 1,112
