Up to 20% off select tools
Coby Kyros MID9742 Camera Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
81
All Time:
727
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Coby Kyros MID9742 Camera Module Replacement, Outer Casing: step 1, image 1 of 1
      • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
      Ask FixBot
    2. Coby Kyros MID9742 Camera Module Replacement: step 2, image 1 of 1
      • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
      Ask FixBot
    3. Coby Kyros MID9742 Camera Module Replacement: step 3, image 1 of 1
      • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
      • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
      • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
      Ask FixBot
    1. Coby Kyros MID9742 Camera Module Replacement, Camera Module: step 4, image 1 of 1
      • Remove the two ribbon cables attached to the logic board.
      Ask FixBot
    2. Coby Kyros MID9742 Camera Module Replacement: step 5, image 1 of 1
      • Remove the tape covering the ribbon cables and remove the camera module.
      Ask FixBot
Author
with
Jake
167 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 81
All Time: 727
