Coby Kyros MID9042 Battery Replacement
    1. Coby Kyros MID9042 Battery Replacement, Battery: step 1, image 1 of 3 Coby Kyros MID9042 Battery Replacement, Battery: step 1, image 2 of 3 Coby Kyros MID9042 Battery Replacement, Battery: step 1, image 3 of 3
      • Before taking the tablet apart, power off the device.
      • Remove anti-slip pads from all four corners of the back of the device with a nylon spudger.
      • Remove the four 1/8" screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. Coby Kyros MID9042 Battery Replacement: step 2, image 1 of 3 Coby Kyros MID9042 Battery Replacement: step 2, image 2 of 3 Coby Kyros MID9042 Battery Replacement: step 2, image 3 of 3
      • Potential for device damage: Be careful not to break the inner plastic tabs while pulling the back cover off.
      • Use an opening tool to wedge the back cover apart from the front.
      • Once the edges are wedged apart, use your hands to remove the back of the tablet.
      Ask FixBot
    3. Coby Kyros MID9042 Battery Replacement: step 3, image 1 of 3 Coby Kyros MID9042 Battery Replacement: step 3, image 2 of 3 Coby Kyros MID9042 Battery Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • With the soldering iron, desolder the red and black battery wires from the circuit board.
      • Use the tweezers to connect the red wire to the positive and the black wire to the negative.
      Ask FixBot
2 other people completed this guide.
Samantha Rollings
349 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 29
All Time: 1,426
