Coby Kyros MID7125 Speaker Replacement
    1. Coby Kyros MID7125 Speaker Replacement, Speaker: step 1, image 1 of 1
      • Use opening too to make small opening in the side of the device.
      • Use plastic opening tool to pry the rest of the panel off.
      Ask FixBot
    2. Coby Kyros MID7125 Speaker Replacement: step 2, image 1 of 1
      • Once inside the device, locate the speakers on the inside of the back panel.
      Ask FixBot
    3. Coby Kyros MID7125 Speaker Replacement: step 3, image 1 of 1
      • Use spudger to pry one speaker up off of the back panel.
      Ask FixBot
    4. Coby Kyros MID7125 Speaker Replacement: step 4, image 1 of 1
      • Desolder the soldering points that connect the speaker to the motherboard.
      Ask FixBot
    5. Coby Kyros MID7125 Speaker Replacement: step 5, image 1 of 1
      • Use a soldering iron to solder the wires of the new speaker to the motherboard.
      • Make sure, when soldering, to connect the red wire to the red and the black wire to the black.
      Ask FixBot
    6. Coby Kyros MID7125 Speaker Replacement: step 6, image 1 of 1
      • Click the new speaker into the spot where you removed the old speaker.
      • Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
      Ask FixBot
Nicole Connelly
1 Reputation
3 Guides authored
UMass Dartmouth, Team 5-2, Martin Fall 2016 Member of UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 25
All Time: 498
