Up to 20% off select tools
Coby KYROS MID7125 Screen Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
6
Past 30 Days:
21
All Time:
600
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 hours
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is the screen of your device cracked and in need of replacement? This guide will walk you through the removal and replacement of your screen.
    1. Coby KYROS MID7125 Screen Replacement, Screen: step 1, image 1 of 1
      • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
      Ask FixBot
    2. Coby KYROS MID7125 Screen Replacement: step 2, image 1 of 3 Coby KYROS MID7125 Screen Replacement: step 2, image 2 of 3 Coby KYROS MID7125 Screen Replacement: step 2, image 3 of 3
      • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger.
      • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
      • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
      • Desolder fifth ribbon cable with soldering station.
      • If soldering is new for you, then follow this useful guide on soldering and desoldering connections.
      Ask FixBot
    3. Coby KYROS MID7125 Screen Replacement: step 3, image 1 of 3 Coby KYROS MID7125 Screen Replacement: step 3, image 2 of 3 Coby KYROS MID7125 Screen Replacement: step 3, image 3 of 3
      • Desolder 2 speaker wires
      • Desolder Battery
      • Desolder antenna wire
      • Disconnect all wires you desoldered
      Ask FixBot
    4. Coby KYROS MID7125 Screen Replacement: step 4, image 1 of 1
      • Desolder the microphone wire
      • Disconnect the wires you just desoldered.
      Ask FixBot
    5. Coby KYROS MID7125 Screen Replacement: step 5, image 1 of 1
      • Remove 4 screws that connect the motherboard to the device.
      Ask FixBot
    6. Coby KYROS MID7125 Screen Replacement: step 6, image 1 of 1
      • Take off motherboard by lifting off right hand side and pulling sideways.
      Ask FixBot
    7. Coby KYROS MID7125 Screen Replacement: step 7, image 1 of 2 Coby KYROS MID7125 Screen Replacement: step 7, image 2 of 2
      • Remove 4 screws on corners of the digitizer and lift off.
      Ask FixBot
    8. Coby KYROS MID7125 Screen Replacement: step 8, image 1 of 2 Coby KYROS MID7125 Screen Replacement: step 8, image 2 of 2
      • Now that the digitizer is disconnected from the screen you can replace the screen.
      • Place the screen face down in front of you facing downward and apply pressure with your thumbs around the outside of the glass to remove the screen.
      • Next, replace with your new screen and follow steps in reverse order to reassemble.
      Ask FixBot
Author
with
Nicole Connelly
1 Reputation
3 Guides authored
UMass Dartmouth, Team 5-2, Martin Fall 2016 Member of UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 21
All Time: 600
