Coby KYROS MID7125 Motherboard Replacement
    1. Coby KYROS MID7125 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel
      Ask FixBot
    2. Coby KYROS MID7125 Motherboard Replacement: step 2, image 1 of 3 Coby KYROS MID7125 Motherboard Replacement: step 2, image 2 of 3 Coby KYROS MID7125 Motherboard Replacement: step 2, image 3 of 3
      • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger
      • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
      • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
      • Desolder fifth ribbon cable with soldering station.
      Ask FixBot
    3. Coby KYROS MID7125 Motherboard Replacement: step 3, image 1 of 3 Coby KYROS MID7125 Motherboard Replacement: step 3, image 2 of 3 Coby KYROS MID7125 Motherboard Replacement: step 3, image 3 of 3
      • Desolder 2 speaker wires
      • Desolder antenna wire
      • Desolder microphone wire
      • Remove all wires you just desoldered.
      Ask FixBot
    4. Coby KYROS MID7125 Motherboard Replacement: step 4, image 1 of 1
      • Desolder the battery wires.
      • If soldering is new to you, then check out this useful guide on soldering and desoldering connections.
      • Remove the battery.
      Ask FixBot
    5. Coby KYROS MID7125 Motherboard Replacement: step 5, image 1 of 1
      • Unscrew 4 screws connecting around mother board using the J0 Phillips head screwdriver.
      Ask FixBot
    6. Coby KYROS MID7125 Motherboard Replacement: step 6, image 1 of 2 Coby KYROS MID7125 Motherboard Replacement: step 6, image 2 of 2
      • Use plastic spudger to take off motherboard by lifting off right hand side and pulling sideways.
      Ask FixBot
Nicole Connelly
1 Reputation
3 Guides authored
UMass Dartmouth, Team 5-2, Martin Fall 2016 Member of UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 576
