Coby DVD209 DVD Laser Reader Replacement
    1. Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: step 1, image 1 of 3 Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: step 1, image 2 of 3 Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Press the eject button to view the laser inside.
      • Using the blue plastic tool and the tweezers, remove the ribbon cable.
      Ask FixBot
    2. Coby DVD209 DVD Laser Reader Replacement: step 2, image 1 of 3 Coby DVD209 DVD Laser Reader Replacement: step 2, image 2 of 3 Coby DVD209 DVD Laser Reader Replacement: step 2, image 3 of 3
      • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
      • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
      • Pry the top of the device open from the right side where the buttons are located.
      Ask FixBot
    3. Coby DVD209 DVD Laser Reader Replacement: step 3, image 1 of 3 Coby DVD209 DVD Laser Reader Replacement: step 3, image 2 of 3 Coby DVD209 DVD Laser Reader Replacement: step 3, image 3 of 3
      • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
      • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
      Ask FixBot
    1. Coby DVD209 DVD Laser Reader Replacement, DVD Laser Reader: step 4, image 1 of 2 Coby DVD209 DVD Laser Reader Replacement, DVD Laser Reader: step 4, image 2 of 2
      • Remove the two 6.35mm screws circled in black with a #1 Philips head screwdriver.
      • Remove one 4mm screw circled in red with a #1 Philips head screwdriver.
      Ask FixBot
    2. Coby DVD209 DVD Laser Reader Replacement: step 5, image 1 of 3 Coby DVD209 DVD Laser Reader Replacement: step 5, image 2 of 3 Coby DVD209 DVD Laser Reader Replacement: step 5, image 3 of 3
      • There are three small 4.5mm springs that can be easily lost. Be careful when lifting up the railing assembly to make sure you don't lose them.
      • The location of the springs are circled.
      • Using two plastic tool removers, lift the two rails up at an angle. Keep the rods angled as shown.
      • The rail at the top of the picture is 82mm and the rail at the bottom of the picture is 65mm.
      Ask FixBot
    3. Coby DVD209 DVD Laser Reader Replacement: step 6, image 1 of 2 Coby DVD209 DVD Laser Reader Replacement: step 6, image 2 of 2
      • Be careful not to lose the spring at the top of the laser.
      • Lift the laser assembly out of the fixture.
      Ask FixBot
    4. Coby DVD209 DVD Laser Reader Replacement: step 7, image 1 of 3 Coby DVD209 DVD Laser Reader Replacement: step 7, image 2 of 3 Coby DVD209 DVD Laser Reader Replacement: step 7, image 3 of 3
      • Remove the rails from the disk reader.
      • Once the top rail is removed, the white gear will come off and under it will be one of the springs.
      Ask FixBot
Yufay Chow
92 Reputation
4 Guides authored
Cal Poly, Team 10-36, Amido Winter 2012 Member of Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 1,231
