Coby DVD209 4-Pin Ribbon Cable Replacement
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: step 1, image 1 of 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: step 1, image 2 of 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
    Ask FixBot
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: step 2, image 1 of 3 Coby DVD209 4-Pin Ribbon Cable Replacement: step 2, image 2 of 3 Coby DVD209 4-Pin Ribbon Cable Replacement: step 2, image 3 of 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
    Ask FixBot
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: step 3, image 1 of 3 Coby DVD209 4-Pin Ribbon Cable Replacement: step 3, image 2 of 3 Coby DVD209 4-Pin Ribbon Cable Replacement: step 3, image 3 of 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
    Ask FixBot
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: step 4, image 1 of 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: step 4, image 2 of 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: step 4, image 3 of 3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
    Ask FixBot
Yufay Chow
92 Reputation
4 Guides authored
Cal Poly, Team 10-36, Amido Winter 2012 Member of Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 36
All Time: 1,373
