Up to 20% off select tools
Coby DVD-R11000 Outer Casing Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
88
All Time:
642
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Coby DVD-R11000 Outer Casing Replacement, Outer Casing: step 1, image 1 of 3 Coby DVD-R11000 Outer Casing Replacement, Outer Casing: step 1, image 2 of 3 Coby DVD-R11000 Outer Casing Replacement, Outer Casing: step 1, image 3 of 3
      • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
      • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
      • It is not required to remove the other seven screws in the middle between the I/O ports.
      Ask FixBot
    2. Coby DVD-R11000 Outer Casing Replacement: step 2, image 1 of 3 Coby DVD-R11000 Outer Casing Replacement: step 2, image 2 of 3 Coby DVD-R11000 Outer Casing Replacement: step 2, image 3 of 3
      • Position the DVD player so that the back is facing you
      • Grab underneath the sides of the DVD player and lift the front of it upwards.
      • Carefully pull the top of the casing off
      Ask FixBot
Author
with
Andrew
501 Reputation
5 Guides authored
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 88
All Time: 642
