Cobra 29 LTD Classic Knobs Replacement
  1. Cobra 29 LTD Classic Knobs Replacement, Power Cable: step 1, image 1 of 2 Cobra 29 LTD Classic Knobs Replacement, Power Cable: step 1, image 2 of 2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
    Ask FixBot
  2. Cobra 29 LTD Classic Knobs Replacement: step 2, image 1 of 2 Cobra 29 LTD Classic Knobs Replacement: step 2, image 2 of 2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
    Ask FixBot
  3. Cobra 29 LTD Classic Knobs Replacement, Microphone: step 3, image 1 of 2 Cobra 29 LTD Classic Knobs Replacement, Microphone: step 3, image 2 of 2
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
    Ask FixBot
  4. Cobra 29 LTD Classic Knobs Replacement: step 4, image 1 of 1
    • Gently unplug the microphone plug.
    Ask FixBot
  5. Cobra 29 LTD Classic Knobs Replacement, Knobs: step 5, image 1 of 1
    • Gently turn the middle four knobs counter-clockwise until they no longer move.
    • The middle four knobs are held in place by friction and do not have a way to keep them in the correct position. When reassembling the middle four knobs, make sure to line up the mark on the knob with the left-most mark on the front panel.
    Ask FixBot
  6. Cobra 29 LTD Classic Knobs Replacement: step 6, image 1 of 2 Cobra 29 LTD Classic Knobs Replacement: step 6, image 2 of 2
    • Insert two plastic opening tools behind the tuning knob.
    • With some force, pry the knob off of the radio.
    • Two opening tools are needed so that you don't break the knob or connector by applying uneven force.
    Ask FixBot
  7. Cobra 29 LTD Classic Knobs Replacement: step 7, image 1 of 3 Cobra 29 LTD Classic Knobs Replacement: step 7, image 2 of 3 Cobra 29 LTD Classic Knobs Replacement: step 7, image 3 of 3
    • Repeat the above procedure with the remaining knobs.
    • The final knob will have a power knob on the end of it. When reassembling, put the power knob on last.
    Ask FixBot
To reassemble your device, align the buttons and push them on.
2 other people completed this guide.
Matt Williams
160 Reputation
1 Guide authored
Cal Poly, Team 11-37, Amido Fall 2013 Member of Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 43
All Time: 5,980
