Cobra 29 LTD Classic Fuse Replacement
Views: 8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
33
Past 30 Days:
103
All Time:
8,049
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The fuse is part of the power cable. It burns out under high electrical current to prevent damage to the radio. The power cable should be disconnected from the power source before starting this guide.
    1. Cobra 29 LTD Classic Fuse Replacement, Power Cable: step 1, image 1 of 2 Cobra 29 LTD Classic Fuse Replacement, Power Cable: step 1, image 2 of 2
      • Turn the power switch, the leftmost knob, counterclockwise to off.
      Ask FixBot
    2. Cobra 29 LTD Classic Fuse Replacement: step 2, image 1 of 2 Cobra 29 LTD Classic Fuse Replacement: step 2, image 2 of 2
      • Turn the device around and firmly pull the power cable plug to remove it from the radio.
      Ask FixBot
    1. Cobra 29 LTD Classic Fuse Replacement, Fuse: step 3, image 1 of 2 Cobra 29 LTD Classic Fuse Replacement, Fuse: step 3, image 2 of 2
      • Simultaneously push the fuse container together and rotate counterclockwise.
      Ask FixBot
    2. Cobra 29 LTD Classic Fuse Replacement: step 4, image 1 of 1
      • Pull the two halves apart.
      Ask FixBot
    3. Cobra 29 LTD Classic Fuse Replacement: step 5, image 1 of 2 Cobra 29 LTD Classic Fuse Replacement: step 5, image 2 of 2
      • Remove the fuse from the case.
      Ask FixBot
danperoni
560 Reputation
4 Guides authored
Cal Poly, Team 11-37, Amido Fall 2013 Member of Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
4 Members
108 Guides authored
1 Guide Comment
Buenas tardes,quisiera saber cuanto AMP se usa en un fusible de radio Cobra 29 LTD Clasic,gracias antisipadas,,,,
Yimbo - Reply Share
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 103
All Time: 8,049
