Cloth Face Mask Nose Bridge Replacement
    1. Cloth Face Mask Nose Bridge Replacement, Nose Bridge: step 1, image 1 of 2 Cloth Face Mask Nose Bridge Replacement, Nose Bridge: step 1, image 2 of 2
      • It's best to wash your mask before and after handling to ensure cleanliness.
      • Lay the mask flat on desired surface.
      • Optional: Steam mask with a clothing iron to completely flatten and remove wrinkles.
      • Caution: Never leave the clothing iron unattended. Use caution when ironing as the machine will be hot to the touch.
      • Measure out the width of your face mask.
      Ask FixBot
    2. Cloth Face Mask Nose Bridge Replacement: step 2, image 1 of 2 Cloth Face Mask Nose Bridge Replacement: step 2, image 2 of 2
      • Using a pen or pencil, mark the insertion point for the pipe cleaners.
      • A fabric pencil would be better suited for markings as it can be easily washed off.
      Ask FixBot
    3. Cloth Face Mask Nose Bridge Replacement: step 3, image 1 of 1
      • Seam rip where the elastic portion is. If there is no elastic present, then seam rip along the top portion of the mask.
      • Caution: Be mindful of where you place your fingers as it is possible to accidentally jab yourself with the seam ripper.
      • Consider using a thimble for protection.
      Ask FixBot
    4. Cloth Face Mask Nose Bridge Replacement: step 4, image 1 of 2 Cloth Face Mask Nose Bridge Replacement: step 4, image 2 of 2
      • Cut a 4” strip of pipe cleaner.
      • Use caution when cutting pipe cleaners with scissors.
      Ask FixBot
    5. Cloth Face Mask Nose Bridge Replacement: step 5, image 1 of 1
      • Position the pipe cleaner where the markings are and fold the fabric over.
      • You may also use this as an opportunity to test out the positioning of the pipe cleaners before sewing the hem.
      Ask FixBot
    6. Cloth Face Mask Nose Bridge Replacement: step 6, image 1 of 1
      • Sew around the pipe cleaner using desired stitch.
      • A basic running stitch is recommended for ease.
      • Try on the mask to ensure the fit is right. Bend the pipe cleaners to best suit your facial frame.
      Ask FixBot
Finish Line
Kayla Vargas
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 44
All Time: 1,205
