Clipper Lighter Flint Replacement
Views: 63K
View statistics:
Past 24 Hours:
38
Past 7 Days:
238
Past 30 Days:
993
All Time:
62,964
Comments: 20
9 comments on steps, 11 guide comments.
Go to guide comments
Completed: 28
28 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Today a lighter is used more than ever and having the means to replace a part on it can go a long way, especially for your pockets. Clipper lighters have the ability to replace the flint so why not take advantage of this and replace the flint instead of buying a new one each time. Plus it's way more eco-friendly!
This replacement should take no time at all and is something absolutely anyone can do; just be sure to have bought your replacement flint.
    1. Clipper Lighter Flint Replacement, Flint: step 1, image 1 of 3 Clipper Lighter Flint Replacement, Flint: step 1, image 2 of 3 Clipper Lighter Flint Replacement, Flint: step 1, image 3 of 3
      • Purchase flint for lighters - should look cylindrical in nature and small.
      Ask FixBot
    2. Clipper Lighter Flint Replacement: step 2, image 1 of 2 Clipper Lighter Flint Replacement: step 2, image 2 of 2
      • Pull upwards on the spark wheel to remove it from the lighter.
      Ask FixBot
    3. Clipper Lighter Flint Replacement: step 3, image 1 of 1
      • Flip the mechanism upside down so that the groove is facing up.
      Ask FixBot
    4. Clipper Lighter Flint Replacement: step 4, image 1 of 2 Clipper Lighter Flint Replacement: step 4, image 2 of 2
      • Use the top of the lighter housing to twist the cap loose.
      • Set aside the lighter once it becomes loose enough to do it by hand.
      Ask FixBot
    5. Clipper Lighter Flint Replacement: step 5, image 1 of 2 Clipper Lighter Flint Replacement: step 5, image 2 of 2
      • Pull on the cap and the spring will come out with it.
      Ask FixBot
    6. Clipper Lighter Flint Replacement: step 6, image 1 of 2 Clipper Lighter Flint Replacement: step 6, image 2 of 2
      • Flip the mechanism and tap on the bottom so that the old flint falls out if there is any left.
      • Use a hard surface if necessary.
      Ask FixBot
    7. Clipper Lighter Flint Replacement: step 7, image 1 of 1
      • Take a new flint and drop it down the tube.
      Ask FixBot
28 other people completed this guide.
Daniel Gherman
841 Reputation
1 Guide authored
11 Guide Comments
thank you very much for the clear instruction, it was very helpful.
Daniel Kalani - Reply Share
SO Thankful 4this! Wish much more could stay out of landfills!! We're such a wasteful country!!
deborah Smith - Reply Share
Easier than I thought...cool dude
Teresa Sigerson - Reply Share
Thanks working again
Anthony Martin - Reply Share
I've got the metal Clipper with a cap over the wheel (EU version). Instead of flicking the wheel with your thumb, you press down on the cap/switch. Now my flint's exhausted and I can't figure out how to remove the cap to change it! Does anyone know?
cherrya.facebook - Reply Share
Past 24 Hours: 38
Past 7 Days: 238
Past 30 Days: 993
All Time: 62,964
