Up to 20% off select tools
Cleaning the Controller Buttons
Views: 7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
31
Past 30 Days:
154
All Time:
7,040
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
You will learn how to take apart the necessary parts of the controller, how to clean the inside, and how certain parts are supposed to aligned or inserted into other parts.
    1. Cleaning the Controller Buttons, Cleaning the Controller Buttons: step 1, image 1 of 2 Cleaning the Controller Buttons, Cleaning the Controller Buttons: step 1, image 2 of 2
      • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
      • Remove the back panel from the controller.
      Ask FixBot
    2. Cleaning the Controller Buttons: step 2, image 1 of 3 Cleaning the Controller Buttons: step 2, image 2 of 3 Cleaning the Controller Buttons: step 2, image 3 of 3
      • Remove the 3 screws (4.8 mm Phillips head) from the back of the white box.
      • Remove the back panel of the joystick box.
      • There are many small plastic components loose in this box; be careful not to lose these.
      • Separate the rubber pads and plastic buttons from the controller.
      Ask FixBot
    3. Cleaning the Controller Buttons: step 3, image 1 of 2 Cleaning the Controller Buttons: step 3, image 2 of 2
      • Using a soft cleaning material, clean the plastic buttons.
      • Using a toothpick, clean the pole slot, shown at the right of the Q-Tip.
      Ask FixBot
    4. Cleaning the Controller Buttons: step 4, image 1 of 2 Cleaning the Controller Buttons: step 4, image 2 of 2
      • Using a damp, soft cleaning material, clean the rubber button pads.
      • To ensure that no electrical damage occurs, ensure that you dry the pieces completely after cleaning them.
      Ask FixBot
    5. Cleaning the Controller Buttons, Put it back together: step 5, image 1 of 1
      • Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
7 other people completed this guide.
Author
with
Jason Gittler
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 154
All Time: 7,040
