Classique 087CQA Switches Replacement
    1. Classique 087CQA Switches Replacement, Switches: step 1, image 1 of 1
      • Begin with the side with switches
      Ask FixBot
    2. Classique 087CQA Switches Replacement: step 2, image 1 of 2 Classique 087CQA Switches Replacement: step 2, image 2 of 2
      • Remove the Phillips PH0 bit
      • Insert the bit into the screwdriver
      Ask FixBot
    3. Classique 087CQA Switches Replacement: step 3, image 1 of 1
      • Unscrew the shell screw (1) with the screwdriver
      • 5mm Phillips flat-head screw
      Ask FixBot
    4. Classique 087CQA Switches Replacement: step 4, image 1 of 1
      • Flip the hair dryer over to the side without switches
      Ask FixBot
    5. Classique 087CQA Switches Replacement: step 5, image 1 of 1
      • Unscrew the shell screw (1) with the screw driver
      Ask FixBot
    6. Classique 087CQA Switches Replacement: step 6, image 1 of 2 Classique 087CQA Switches Replacement: step 6, image 2 of 2
      • Remove the bit from the screwdriver and insert the Phillips PH2 bit
      Ask FixBot
    7. Classique 087CQA Switches Replacement: step 7, image 1 of 1
      • Unscrew the remaining shell screws (5) with the screwdriver
      • 15mm Phillips round-head screws
      Ask FixBot
    8. Classique 087CQA Switches Replacement: step 8, image 1 of 2 Classique 087CQA Switches Replacement: step 8, image 2 of 2
      • Gently pull the two sides apart
      • Separate each side
      Ask FixBot
    9. Classique 087CQA Switches Replacement: step 9, image 1 of 3 Classique 087CQA Switches Replacement: step 9, image 2 of 3 Classique 087CQA Switches Replacement: step 9, image 3 of 3
      • Pull up on the switches
      Ask FixBot
    10. Classique 087CQA Switches Replacement: step 10, image 1 of 1
      • Verify wires are connected to each switch and are in good condition
      Ask FixBot
    11. Classique 087CQA Switches Replacement: step 11, image 1 of 1
      • Reseat the switches
      Ask FixBot
    12. Classique 087CQA Switches Replacement: step 12, image 1 of 3 Classique 087CQA Switches Replacement: step 12, image 2 of 3 Classique 087CQA Switches Replacement: step 12, image 3 of 3
      • Check power cord for tears or kinks
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 816
