Citroen C4 Grand Picasso Rear Wing Light Replacement
    1. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Broken rear light: step 1, image 1 of 1
      • Make sure you find the right component for the correct side of your car.
      • You've broken your rear light. Unfortunately you can't just replace the transparent cover. The whole unit needs replacement.
      Ask FixBot
    2. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Locate the internal panel opening: step 2, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • You can lift the cover carefully just by using a flexible plastic card or a flat screwdriver.
      • Locate the internal panel opening. Use the little dent on the top corner of the little cover to open it.
      Ask FixBot
    3. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Lift and remove the little panel cover: step 3, image 1 of 1
      • Lift the cover from the top right corner.
      Ask FixBot
    4. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Locate screw and electric cable connector: step 4, image 1 of 1
      • The top most electric connector will need your attention.
      • In order to remove the broken light you'll have to remove just 3 screws, two are behind the little panel. One is the one right most visible in the picture.
      Ask FixBot
    5. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Unscrew the light unit: step 5, image 1 of 2 Citroen C4 Grand Picasso  Rear Wing Light Replacement, Unscrew the light unit: step 5, image 2 of 2
      • Unscrew the light unit with a 6 points star tip. Of the 3 screws, two are behind the panel and one is outside near the edge of the lid.
      Ask FixBot
    6. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Disconnect the cable: step 6, image 1 of 1
      • Disconnect the topmost cable connector. This is also the bigger one in size.
      Ask FixBot
    7. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Note the screw holes and the connector: step 7, image 1 of 1
      • Also the cabling connector is now detached.
      • Note the 3 holes left where the screws were removed.
      Ask FixBot
    8. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Replace the light unit: step 8, image 1 of 1
      • Connect the cable and fit the small cover lid.
      • Put the screws back to fix the light unit firmly.
      • With the new light, slide the cable in through the square hole and push the new unit in place.
      • Remove the broken unit, wipe the edges holding the unit clean. Now repeat these steps in reverse to fit the new light unit.
      Ask FixBot
    9. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Job done: step 9, image 1 of 1
      • Unfortunately the unit is tight sealed and it is not possible to change only the transparent cover. In that way the light is water tight and free of finger prints that may be left in tempering with replacing internal bits of the unit.
      • Time and money saved. Job done!
      Ask FixBot
Test that all lights display correctly for the appropriate actions before leaving the light to be, and you're done!
7 other people completed this guide.
Carlo Zinzani
307 Reputation
1 Guide authored
2 Guide Comments
@uca What year is the vehicle that you are repairing? I only ask as I know certain cars have different design processes that make repairs different for each generation or model
Medical - Reply Share
Worked a treat! Thank you :-)
The above were very accurate and the whole job took me about 20 mins (which included finding the correct-sized torx bit
2019 C4 Sparectourer
Tony Stevens - Reply Share
Past 24 Hours: 7
Past 7 Days: 63
Past 30 Days: 299
All Time: 10,417
