Up to 20% off select tools
Citizen Promaster Dive Automatic Strap Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
11
Past 7 Days:
69
Past 30 Days:
263
All Time:
3,814
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
When you own a watch for an extended amount of time there is going to be wear on the strap. Instead of buying a new watch you can simply replace the strap.
    1. Citizen Promaster Dive Automatic Strap Replacement, Strap: step 1, image 1 of 3 Citizen Promaster Dive Automatic Strap Replacement, Strap: step 1, image 2 of 3 Citizen Promaster Dive Automatic Strap Replacement, Strap: step 1, image 3 of 3
      • Flip your watch to the back.
      • Insert the small end with the bar between the fork. Press outwards; when you feel the pressure, pull up slowly.
      Ask FixBot
    2. Citizen Promaster Dive Automatic Strap Replacement: step 2, image 1 of 3 Citizen Promaster Dive Automatic Strap Replacement: step 2, image 2 of 3 Citizen Promaster Dive Automatic Strap Replacement: step 2, image 3 of 3
      • When the bar pops out, pull the strap out.
      • Remove the bar from the strap and place the spring bar in the new strap.
      Ask FixBot
    3. Citizen Promaster Dive Automatic Strap Replacement: step 3, image 1 of 2 Citizen Promaster Dive Automatic Strap Replacement: step 3, image 2 of 2
      • Insert one end of the spring bar into one of the holes and hold it in place.
      Ask FixBot
    4. Citizen Promaster Dive Automatic Strap Replacement: step 4, image 1 of 2 Citizen Promaster Dive Automatic Strap Replacement: step 4, image 2 of 2
      • With the larger end press the bar in.
      • Guide to the hole.
      Ask FixBot
Replace the other strap by following the same instructions.
Author
with
Ismael Vega
133 Reputation
1 Guide authored
1 Guide Comment
After the automatic watch fell to the ground, the back glass was broken and it stopped working
Zerihun Denu - Reply Share
Past 24 Hours: 11
Past 7 Days: 69
Past 30 Days: 263
All Time: 3,814
