Cisco Meraki MC74-HW Phone Sensor Replacement
  1. Cisco Meraki MC74-HW Phone Sensor Replacement, Back Housing and Device Stand: step 1, image 1 of 3 Cisco Meraki MC74-HW Phone Sensor Replacement, Back Housing and Device Stand: step 1, image 2 of 3 Cisco Meraki MC74-HW Phone Sensor Replacement, Back Housing and Device Stand: step 1, image 3 of 3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
    Ask FixBot
  2. Cisco Meraki MC74-HW Phone Sensor Replacement: step 2, image 1 of 2 Cisco Meraki MC74-HW Phone Sensor Replacement: step 2, image 2 of 2
    • Lift the stand off the device.
    Ask FixBot
  3. Cisco Meraki MC74-HW Phone Sensor Replacement: step 3, image 1 of 3 Cisco Meraki MC74-HW Phone Sensor Replacement: step 3, image 2 of 3 Cisco Meraki MC74-HW Phone Sensor Replacement: step 3, image 3 of 3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
    Ask FixBot
  4. Cisco Meraki MC74-HW Phone Sensor Replacement: step 4, image 1 of 2 Cisco Meraki MC74-HW Phone Sensor Replacement: step 4, image 2 of 2
    • Separate the back housing cover from the device completely.
    Ask FixBot
  5. Cisco Meraki MC74-HW Phone Sensor Replacement, Phone Sensor: step 5, image 1 of 2 Cisco Meraki MC74-HW Phone Sensor Replacement, Phone Sensor: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the ribbon from the phone sensor board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
    Ask FixBot
  6. Cisco Meraki MC74-HW Phone Sensor Replacement: step 6, image 1 of 3 Cisco Meraki MC74-HW Phone Sensor Replacement: step 6, image 2 of 3 Cisco Meraki MC74-HW Phone Sensor Replacement: step 6, image 3 of 3
    • Remove the two 1.2 mm screws holding the phone sensor using a Phillips #0 screwdriver.
    • Carefully lift the phone sensor to remove it from the device.
    Ask FixBot
Anthony Kairouz
253 Reputation
3 Guides authored
UMass Dartmouth, Team 1-5, Simcock Fall 2021 Member of UMass Dartmouth, Team 1-5, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G5
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 24
All Time: 379
