Cisco Aironet 1242 Dissasembly
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
91
All Time:
1,883
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Disassembly guide for Cisco Aironet 1242ag Access Point
    1. Cisco Aironet 1242 Dissasembly, Remove the screws: step 1, image 1 of 2 Cisco Aironet 1242 Dissasembly, Remove the screws: step 1, image 2 of 2
      • The equipment cover is held by 4 screws.
      Ask FixBot
    2. Cisco Aironet 1242 Dissasembly, Removing the cover: step 2, image 1 of 1
      • Once the 4 screws are removed, push to the side to remove the cover.
      Ask FixBot
    3. Cisco Aironet 1242 Dissasembly, Disassembling the main board: step 3, image 1 of 3 Cisco Aironet 1242 Dissasembly, Disassembling the main board: step 3, image 2 of 3 Cisco Aironet 1242 Dissasembly, Disassembling the main board: step 3, image 3 of 3
      • The card is attached to the bottom plate by 4 screws
      • Before removing the logic board, disconnect the antenna cables in both parts of the device.
      • There is a total of 4 cables. Use a tweezer or a spudger to disconnect them.
      Ask FixBot
    4. Cisco Aironet 1242 Dissasembly, Device disassembled: step 4, image 1 of 3 Cisco Aironet 1242 Dissasembly, Device disassembled: step 4, image 2 of 3 Cisco Aironet 1242 Dissasembly, Device disassembled: step 4, image 3 of 3
      • Write the wisdom here.
      Ask FixBot
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Eneider Colina
2,405 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 91
All Time: 1,883
