Up to 20% off select tools
Circular Saw Blade Replacement
Views: 13K
View statistics:
Past 24 Hours:
7
Past 7 Days:
89
Past 30 Days:
436
All Time:
13,462
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Whether your circular saw blade is worn out, or you just want to switch it out for a different style, it’s really easy to swap out blades on pretty much any circular saw—and it takes just a few minutes.
This guide uses a Ryobi P504G circular saw, but the process is very similar for most circular saws.
    1. Circular Saw Blade Replacement, Blade: step 1, image 1 of 2 Circular Saw Blade Replacement, Blade: step 1, image 2 of 2
      • Unplug your circular saw or remove the battery before replacing the blade!
      Ask FixBot
    2. Circular Saw Blade Replacement: step 2, image 1 of 3 Circular Saw Blade Replacement: step 2, image 2 of 3 Circular Saw Blade Replacement: step 2, image 3 of 3
      • Press and hold down the blade lock button to keep the blade from turning while you loosen it.
      • Loosen the arbor's hex bolt in the center of the blade using a 5mm hex key, making sure to loosen clockwise since the bolt threads are reversed.
      • Your circular saw may already come with a hex key.
      Ask FixBot
    3. Circular Saw Blade Replacement: step 3, image 1 of 2 Circular Saw Blade Replacement: step 3, image 2 of 2
      • Once loosened, continue unscrewing the bolt with your fingers and remove it from the saw.
      Ask FixBot
    4. Circular Saw Blade Replacement: step 4, image 1 of 2 Circular Saw Blade Replacement: step 4, image 2 of 2
      • Remove the arbor washer.
      Ask FixBot
    5. Circular Saw Blade Replacement: step 5, image 1 of 3 Circular Saw Blade Replacement: step 5, image 2 of 3 Circular Saw Blade Replacement: step 5, image 3 of 3
      • Completely retract the blade guard.
      • You can hold the blade guard in place with a clamp while you change the blade.
      Ask FixBot
    6. Circular Saw Blade Replacement: step 6, image 1 of 3 Circular Saw Blade Replacement: step 6, image 2 of 3 Circular Saw Blade Replacement: step 6, image 3 of 3
      • Set the circular saw on its side and carefully lift up the blade to unseat it from the arbor.
      • Slowly slide out the blade.
      • Use extreme caution when handling the blade!
      Ask FixBot
    7. Circular Saw Blade Replacement: step 7, image 1 of 1
      • When inserting the new blade, be sure to note its rotation and install it in the correct orientation.
      Ask FixBot
3 other people completed this guide.
Author
with
Craig Lloyd
43,853 Reputation
82 Guides authored
3 Guide Comments
Hello!
I learned a lot of important things, but I have a Question that is this Circular Saw perfect to cut Concrete Pavers?
F6 Adhesive Tape - Reply Share
I think you need a cutting disc in your circular saw
to cut concrete.
Toon Konings - Reply Share
the problem is that cutting concrete with a concrete disk produces a lot of concrete dust. It will kill your machine. It is not possible to stop the dust by pouring water as you would do with a tile cutting machine.
vief - Reply Share
Past 24 Hours: 7
Past 7 Days: 89
Past 30 Days: 436
All Time: 13,462
