Circo Monkey Alarm Clock Motor Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
102
All Time:
1,777
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Tools
    1. Circo Monkey Alarm Clock Motor Replacement, Screw Removal: step 1, image 1 of 2 Circo Monkey Alarm Clock Motor Replacement, Screw Removal: step 1, image 2 of 2
      • Remove all six 7.3 mm screws with a #00 Phillips head screwdriver.
      Ask FixBot
    2. Circo Monkey Alarm Clock Motor Replacement, Splitting the Shell in Half: step 2, image 1 of 1
      • Firmly pull each half apart.
      Ask FixBot
    1. Circo Monkey Alarm Clock Motor Replacement, Clock Motor: step 3, image 1 of 2 Circo Monkey Alarm Clock Motor Replacement, Clock Motor: step 3, image 2 of 2
      • Once the clock is apart, carefully pull both halves until the clock is in two separate halves.
      Ask FixBot
    2. Circo Monkey Alarm Clock Motor Replacement: step 4, image 1 of 2 Circo Monkey Alarm Clock Motor Replacement: step 4, image 2 of 2
      • Unscrew the two 2 mm screws with a #00 Phillips Head screwdriver.
      Ask FixBot
    3. Circo Monkey Alarm Clock Motor Replacement: step 5, image 1 of 3 Circo Monkey Alarm Clock Motor Replacement: step 5, image 2 of 3 Circo Monkey Alarm Clock Motor Replacement: step 5, image 3 of 3
      • Pull off the clock motor housing and un-clip the 4 clips on each side.
      Ask FixBot
    4. Circo Monkey Alarm Clock Motor Replacement: step 6, image 1 of 1
      • Repair any lose or misplaced gears or wiring.
      Ask FixBot
3 other people completed this guide.
Frank
151 Reputation
1 Guide authored
USF Tampa, Team 19-1, Blackwell Winter 2015 Member of USF Tampa, Team 19-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 102
All Time: 1,777
