Up to 20% off select tools
Cirago M9030 Screen Protector Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
86
All Time:
1,518
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Cirago M9030 Screen Protector Replacement, Cover: step 1, image 1 of 1
      • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
      Ask FixBot
    2. Cirago M9030 Screen Protector Replacement: step 2, image 1 of 1
      • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
      • Remove the warranty sticker across the bottom.
      Ask FixBot
    3. Cirago M9030 Screen Protector Replacement: step 3, image 1 of 2 Cirago M9030 Screen Protector Replacement: step 3, image 2 of 2
      • Gently take the cover apart using your hands separating the top and bottom.
      • The outer shell is expected to easily come apart.
      Ask FixBot
    1. Cirago M9030 Screen Protector Replacement, Hard Drive: step 4, image 1 of 1
      • Make sure that the screen of the device is facing down.
      Ask FixBot
    2. Cirago M9030 Screen Protector Replacement: step 5, image 1 of 3 Cirago M9030 Screen Protector Replacement: step 5, image 2 of 3 Cirago M9030 Screen Protector Replacement: step 5, image 3 of 3
      • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
      • Raise the bottom edge of the hard drive 15 degrees up from the device.
      Ask FixBot
    3. Cirago M9030 Screen Protector Replacement: step 6, image 1 of 3 Cirago M9030 Screen Protector Replacement: step 6, image 2 of 3 Cirago M9030 Screen Protector Replacement: step 6, image 3 of 3
      • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
      Ask FixBot
    1. Cirago M9030 Screen Protector Replacement, IDE Connector: step 7, image 1 of 2 Cirago M9030 Screen Protector Replacement, IDE Connector: step 7, image 2 of 2
      • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
      Ask FixBot
    2. Cirago M9030 Screen Protector Replacement: step 8, image 1 of 1
      • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
      Ask FixBot
    3. Cirago M9030 Screen Protector Replacement: step 9, image 1 of 2 Cirago M9030 Screen Protector Replacement: step 9, image 2 of 2
      • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
      • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
      Ask FixBot
    4. Cirago M9030 Screen Protector Replacement: step 10, image 1 of 1
      • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
      Ask FixBot
    5. Cirago M9030 Screen Protector Replacement: step 11, image 1 of 2 Cirago M9030 Screen Protector Replacement: step 11, image 2 of 2
      • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
      • Completely remove the IDE connector from the device.
      Ask FixBot
    1. Cirago M9030 Screen Protector Replacement, Motherboard: step 12, image 1 of 2 Cirago M9030 Screen Protector Replacement, Motherboard: step 12, image 2 of 2
      • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
      • Completely remove the motherboard.
      • The motherboard should slide out easily.
      Ask FixBot
    1. Cirago M9030 Screen Protector Replacement, Screen Protector: step 13, image 1 of 1
      • Locate the plastic screen protector on the front cover.
      Ask FixBot
    2. Cirago M9030 Screen Protector Replacement: step 14, image 1 of 1
      • Grasping the sides of the cover, gently press on screen protector from the inside of the front cover to pop out the screen protector.
      Ask FixBot
Author
with
Ryan Sutardji
171 Reputation
7 Guides authored
Cal Poly, Team 1-4, Regan SU 2012 Member of Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 86
All Time: 1,518
