Cirago M9030 IDE Connector Replacement
    1. Cirago M9030 IDE Connector Replacement, Cover: step 1, image 1 of 1
      • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
      Ask FixBot
    2. Cirago M9030 IDE Connector Replacement: step 2, image 1 of 1
      • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
      • Remove the warranty sticker across the bottom.
      Ask FixBot
    3. Cirago M9030 IDE Connector Replacement: step 3, image 1 of 2 Cirago M9030 IDE Connector Replacement: step 3, image 2 of 2
      • Gently take the cover apart using your hands separating the top and bottom.
      • The outer shell is expected to easily come apart.
      Ask FixBot
    1. Cirago M9030 IDE Connector Replacement, Hard Drive: step 4, image 1 of 1
      • Make sure that the screen of the device is facing down.
      Ask FixBot
    2. Cirago M9030 IDE Connector Replacement: step 5, image 1 of 3 Cirago M9030 IDE Connector Replacement: step 5, image 2 of 3 Cirago M9030 IDE Connector Replacement: step 5, image 3 of 3
      • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
      • Raise the bottom edge of the hard drive 15 degrees up from the device.
      Ask FixBot
    3. Cirago M9030 IDE Connector Replacement: step 6, image 1 of 3 Cirago M9030 IDE Connector Replacement: step 6, image 2 of 3 Cirago M9030 IDE Connector Replacement: step 6, image 3 of 3
      • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
      Ask FixBot
    1. Cirago M9030 IDE Connector Replacement, IDE Connector: step 7, image 1 of 2 Cirago M9030 IDE Connector Replacement, IDE Connector: step 7, image 2 of 2
      • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
      Ask FixBot
    2. Cirago M9030 IDE Connector Replacement: step 8, image 1 of 1
      • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
      Ask FixBot
    3. Cirago M9030 IDE Connector Replacement: step 9, image 1 of 2 Cirago M9030 IDE Connector Replacement: step 9, image 2 of 2
      • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
      • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
      Ask FixBot
    4. Cirago M9030 IDE Connector Replacement: step 10, image 1 of 1
      • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
      Ask FixBot
    5. Cirago M9030 IDE Connector Replacement: step 11, image 1 of 2 Cirago M9030 IDE Connector Replacement: step 11, image 2 of 2
      • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
      • Completely remove the IDE connector from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Once you've replaced the IDE connector and reassembled your Cirago M9030, your device should be able to detect hard drives properly again. If everything is connected correctly, your repair is complete. Great job!
Ryan Sutardji
171 Reputation
7 Guides authored
Cal Poly, Team 1-4, Regan SU 2012 Member of Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 1,340
