Cirago M9030 Cover Replacement
    1. Cirago M9030 Cover Replacement, Cover: step 1, image 1 of 1
      • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
      Ask FixBot
    2. Cirago M9030 Cover Replacement: step 2, image 1 of 1
      • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
      • Remove the warranty sticker across the bottom.
      Ask FixBot
    3. Cirago M9030 Cover Replacement: step 3, image 1 of 2 Cirago M9030 Cover Replacement: step 3, image 2 of 2
      • Gently take the cover apart using your hands separating the top and bottom.
      • The outer shell is expected to easily come apart.
      Ask FixBot
In order to reassemble your device, follow these instructions in reverse order.
Ryan Sutardji
171 Reputation
7 Guides authored
Cal Poly, Team 1-4, Regan SU 2012 Member of Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 1,228
