Cingular 8125 Pocket PC Screen Replacement
      • Hold the phone with the back (camera side) facing you. Slide the battery cover off of the phone.
      Ask FixBot
      • Pull the battery out by lifting the black tab on the left side of the battery.
      Ask FixBot
      • Remove the camera cover of the phone, using your light blue wedge tool.
      Ask FixBot
      • Unscrew the four black Torx head screws, found in each corner of the back.
      • Warning: Unscrewing the screw indicated in the picture will void any warranty on the phone.
      Ask FixBot
    1. Cingular 8125 Pocket PC Screen Replacement: step 5, image 1 of 1
      • Unscrew the black Phillips head screw below the right speaker.
      Ask FixBot
      • After removing the screw, pull up on the motherboard to release it from the circuit board (green tab, see Figure 11). This will simply snap out, and does not require too much force.
      Ask FixBot
    2. Cingular 8125 Pocket PC Screen Replacement: step 7, image 1 of 1
      • Remove the keyboard by unscrewing the two pairs of silver Torx head screws that run along the sliding tracks.
      Ask FixBot
    3. Cingular 8125 Pocket PC Screen Replacement: step 8, image 1 of 1
      • Remove the four silver Phillips head screws from the screened half of the phone.
      Ask FixBot
    4. Cingular 8125 Pocket PC Screen Replacement: step 9, image 1 of 1
      • Use the light blue wedge tool to remove the back. The circuit board will slide out of the slot and will stay attached to the remaining front half of the phone.
      Ask FixBot
    5. Cingular 8125 Pocket PC Screen Replacement: step 10, image 1 of 1
      • Unscrew the four Phillips head screws that attach the screen to the front case.
      Ask FixBot
      • Remove the circuit board; pull it apart at the orange tab. This will detach the screen from its circuit board.
      Ask FixBot
    6. Cingular 8125 Pocket PC Screen Replacement: step 12, image 1 of 1
      • Attach the new screen by aligning the orange tab with the beige rectangle on the circuit. Secure by pushing down on the bronze piece.
      Ask FixBot
      • Place screen back into front cover.
      Ask FixBot
      • Screw the four smallest silver Torx head screws into the circuit board, which will attach it to the front cover.
      Ask FixBot
      • Feed the circuit board through the back piece.
      Ask FixBot
      • Use the four Phillips head silver screws to attach the back piece to the front of the phone.
      Ask FixBot
    7. Cingular 8125 Pocket PC Screen Replacement: step 17, image 1 of 1
      • Slide the circuit board through the slot in the keyboard.
      Ask FixBot
      • Attach the keyboard to the sliding tracks using the four silver Torx screws.
      Ask FixBot
    8. Cingular 8125 Pocket PC Screen Replacement: step 19, image 1 of 1
      • Attach the motherboard to the circuit board, aligning the two white rectangles until they snap into place. Lay motherboard into place.
      Ask FixBot
    9. Cingular 8125 Pocket PC Screen Replacement: step 20, image 1 of 1
      • Secure the motherboard by screwing the small black Phillips head screw into place, located below the right speaker. Note: You may need to remove the right speaker in order to replace this screw.
      Ask FixBot
      • Place the back cover onto the motherboard, clicking it into place.
      Ask FixBot
    10. Cingular 8125 Pocket PC Screen Replacement: step 22, image 1 of 1
      • Secure the back cover by screwing the four long, black Torx screws into the four corners of the back cover.
      Ask FixBot
    11. Cingular 8125 Pocket PC Screen Replacement: step 23, image 1 of 1
      • Replace the camera cover.
      Ask FixBot
    12. Cingular 8125 Pocket PC Screen Replacement: step 24, image 1 of 1
      • Replace battery, keeping the black tab available to grab.
      Ask FixBot
    13. Cingular 8125 Pocket PC Screen Replacement: step 25, image 1 of 1
      • Slide the battery cover back into place.
      Ask FixBot
Laura Kimberly Simonds
301 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,150
