Cineyo BT-03 Device Page Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
70
All Time:
491
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will take you step by step through the steps of replacing your devices buttons.
Parts
Tools
    1. Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: step 1, image 1 of 3 Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: step 1, image 2 of 3 Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: step 1, image 3 of 3
      • Remove the top (button side) rubber cover using your hands.
      Ask FixBot
    2. Cineyo BT-03 Device Page Button Replacement: step 2, image 1 of 2 Cineyo BT-03 Device Page Button Replacement: step 2, image 2 of 2
      • Flip over the device and remove the bottom rubber cover using your hands.
      Ask FixBot
    3. Cineyo BT-03 Device Page Button Replacement: step 3, image 1 of 3 Cineyo BT-03 Device Page Button Replacement: step 3, image 2 of 3 Cineyo BT-03 Device Page Button Replacement: step 3, image 3 of 3
      • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
      Ask FixBot
    4. Cineyo BT-03 Device Page Button Replacement: step 4, image 1 of 3 Cineyo BT-03 Device Page Button Replacement: step 4, image 2 of 3 Cineyo BT-03 Device Page Button Replacement: step 4, image 3 of 3
      • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
      • The cover should remain as one solid piece.
      Ask FixBot
    5. Cineyo BT-03 Device Page Button Replacement: step 5, image 1 of 1
      • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
      Ask FixBot
    6. Cineyo BT-03 Device Page Button Replacement: step 6, image 1 of 1
      • Gently pull apart the two sections of the device.
      Ask FixBot
    1. Cineyo BT-03 Device Page Button Replacement, Button: step 7, image 1 of 2 Cineyo BT-03 Device Page Button Replacement, Button: step 7, image 2 of 2
      • With a Phillips #1 screwdriver, remove the two 5mm screws which attach the button mount to the plastic casing of the device.
      Ask FixBot
    2. Cineyo BT-03 Device Page Button Replacement: step 8, image 1 of 2 Cineyo BT-03 Device Page Button Replacement: step 8, image 2 of 2
      • Using a plastic opening tool, pry the button mount off of the plastic casing of the device.
      Ask FixBot
    3. Cineyo BT-03 Device Page Button Replacement: step 9, image 1 of 2 Cineyo BT-03 Device Page Button Replacement: step 9, image 2 of 2
      • Using a soldering iron and iFixit’s Soldering Guide, remove the individual buttons.
      Ask FixBot
Rene Klopf
487 Reputation
4 Guides authored
Baylor, Team 8-3, Whitney Spring 2017 Member of Baylor, Team 8-3, Whitney Spring 2017
BU-WHITNEY-S17S8G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 70
All Time: 491
