Chumby One Speaker Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
98
All Time:
648
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows how to replace the Chumby One speaker.
Tools
    1. Chumby One Speaker Replacement, Chassis: step 1, image 1 of 1
      • Remove 4 self-adhesive plastic dots covering the screw holes.
      Ask FixBot
    2. Chumby One Speaker Replacement: step 2, image 1 of 1
      • Remove the four 2mm screws with a Phillips screwdriver.
      Ask FixBot
    3. Chumby One Speaker Replacement: step 3, image 1 of 1
      • Remove the back and bottom cover.
      Ask FixBot
    4. Chumby One Speaker Replacement: step 4, image 1 of 1
      • Disconnect the battery connector from the motherboard with a plastic opening tool.
      Ask FixBot
    5. Chumby One Speaker Replacement: step 5, image 1 of 1
      • Disconnect the microphone connector from the motherboard with a plastic opening tool.
      Ask FixBot
    6. Chumby One Speaker Replacement: step 6, image 1 of 1
      • Remove the display ribbon cable from its socket with a plastic opening tool.
      Ask FixBot
    7. Chumby One Speaker Replacement: step 7, image 1 of 1
      • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
      Ask FixBot
    8. Chumby One Speaker Replacement: step 8, image 1 of 1
      • Remove the four 6mm screws using a PH000 bit on the inner chassis.
      Ask FixBot
    9. Chumby One Speaker Replacement: step 9, image 1 of 1
      • Remove the inner components from the outer shell.
      Ask FixBot
    1. Chumby One Speaker Replacement, Speaker: step 10, image 1 of 1
      • Remove the speaker wire connector from the motherboard.
      Ask FixBot
    2. Chumby One Speaker Replacement: step 11, image 1 of 2 Chumby One Speaker Replacement: step 11, image 2 of 2
      • Remove the four 5mm screws on the speaker base with a Phillips PH00 screwdriver bit.
      Ask FixBot
    3. Chumby One Speaker Replacement: step 12, image 1 of 1
      • Remove the speaker.
      Ask FixBot
Jordan Houchins
401 Reputation
4 Guides authored
IUPUI, Team S3-G3, Baechle Spring 2017 Member of IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 98
All Time: 648
