Up to 20% off select tools
Chumby One Motherboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
93
All Time:
920
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
A guide to show how to replace Chumby One motherboard.
    1. Chumby One Motherboard Replacement, Chassis: step 1, image 1 of 1
      • Remove 4 self-adhesive plastic dots covering the screw holes.
      Ask FixBot
    2. Chumby One Motherboard Replacement: step 2, image 1 of 1
      • Remove the four 2mm screws with a Phillips screwdriver.
      Ask FixBot
    3. Chumby One Motherboard Replacement: step 3, image 1 of 1
      • Remove the back and bottom cover.
      Ask FixBot
    4. Chumby One Motherboard Replacement: step 4, image 1 of 1
      • Disconnect the battery connector from the motherboard with a plastic opening tool.
      Ask FixBot
    5. Chumby One Motherboard Replacement: step 5, image 1 of 1
      • Disconnect the microphone connector from the motherboard with a plastic opening tool.
      Ask FixBot
    6. Chumby One Motherboard Replacement: step 6, image 1 of 1
      • Remove the display ribbon cable from its socket with a plastic opening tool.
      Ask FixBot
    7. Chumby One Motherboard Replacement: step 7, image 1 of 1
      • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
      Ask FixBot
    8. Chumby One Motherboard Replacement: step 8, image 1 of 1
      • Remove the four 6mm screws using a PH000 bit on the inner chassis.
      Ask FixBot
    9. Chumby One Motherboard Replacement: step 9, image 1 of 1
      • Remove the inner components from the outer shell.
      Ask FixBot
    1. Chumby One Motherboard Replacement, Motherboard: step 10, image 1 of 1
      • Remove the speaker connector using a plastic spudger.
      Ask FixBot
    2. Chumby One Motherboard Replacement: step 11, image 1 of 1
      • Remove the Chumby button connector using a plastic spudger.
      Ask FixBot
    3. Chumby One Motherboard Replacement: step 12, image 1 of 1
      • Remove three 6mm screws using a PH000 bit.
      Ask FixBot
    4. Chumby One Motherboard Replacement: step 13, image 1 of 1
      • Remove the motherboard by pulling straight away from the housing.
      • Removing the motherboard there are 2 pins and socket connectors that may cause injury.
      Ask FixBot
Author
with
Jordan Houchins
401 Reputation
4 Guides authored
IUPUI, Team S3-G3, Baechle Spring 2017 Member of IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 93
All Time: 920
