Chrysler Pacifica 2004 Water Pump Replacement
    • Disconnect battery cables from battery posts.
    Ask FixBot
    • Safely Jack up car to remove the passenger side front tire.
    • Remove splash guard in wheel well by removing Phillips head screws around parameter and a few plastic clips.
    Ask FixBot
    • unscrew one fastener and disconnect any hoses to the engine.
    •  two additional 'push-on' connecting points on the underside.
    •  disconnect the baffles to the intake manifold(optional but makes much needed room)
    • Remove sensor on the baffles which can be pulled off by first sliding a red tab on the electrical connection.
    Ask FixBot
    • Unscrew the white knob on the driver side bottom of the radiator.
    • Remove fill cap to allow for quicker drain
    Ask FixBot
    • Some people will remove the engine fan to allow for more working space.
    Ask FixBot
4 other people completed this guide.
Robert Torres
225 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 6,319
