Chromo Noria Speaker Replacement
    1. Chromo Noria Speaker  Replacement, Back Panel: step 1, image 1 of 3 Chromo Noria Speaker  Replacement, Back Panel: step 1, image 2 of 3 Chromo Noria Speaker  Replacement, Back Panel: step 1, image 3 of 3
      • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
      • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
      Ask FixBot
    2. Chromo Noria Speaker  Replacement: step 2, image 1 of 1
      • Carefully turn the device over.
      • Lay the back panel aside so you can see the device's parts.
      Ask FixBot
    1. Chromo Noria Speaker  Replacement, Speaker: step 3, image 1 of 1
      • Using your spudger tool, remove speaker from the backboard.
      Ask FixBot
    2. Chromo Noria Speaker  Replacement: step 4, image 1 of 2 Chromo Noria Speaker  Replacement: step 4, image 2 of 2
      • Using the spudger tool, detach the speaker from the back of the screen.
      Ask FixBot
    3. Chromo Noria Speaker  Replacement: step 5, image 1 of 1
      • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
      • Using a Soldering Iron, desolder both wires from the motherboard.
      Ask FixBot
Ryan Rho
201 Reputation
2 Guides authored
Baylor, Team 5-6, Williams Fall 2016 Member of Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 407
