Chromo Noria Battery Replacement
    1. Chromo Noria Battery Replacement, Back Panel: step 1, image 1 of 3 Chromo Noria Battery Replacement, Back Panel: step 1, image 2 of 3 Chromo Noria Battery Replacement, Back Panel: step 1, image 3 of 3
      • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
      • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
      Ask FixBot
    2. Chromo Noria Battery Replacement: step 2, image 1 of 1
      • Carefully turn the device over.
      • Lay the back panel aside so you can see the device's parts.
      Ask FixBot
    1. Chromo Noria Battery Replacement, Battery: step 3, image 1 of 3 Chromo Noria Battery Replacement, Battery: step 3, image 2 of 3 Chromo Noria Battery Replacement, Battery: step 3, image 3 of 3
      • Place your finger at the end of the tape closest to the battery.
      • Peel the tape towards the flex cables to free the battery wires.
      Ask FixBot
    2. Chromo Noria Battery Replacement: step 4, image 1 of 3 Chromo Noria Battery Replacement: step 4, image 2 of 3 Chromo Noria Battery Replacement: step 4, image 3 of 3
      • Using the spudger tool, place the tool along an edge of the battery.
      • Be careful not to bend or break the battery! Batteries contain hazards materials.
      • Move the spudger around the edges of the battery to detach it from the tablet.
      Ask FixBot
    3. Chromo Noria Battery Replacement: step 5, image 1 of 1
      • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
      • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
      • Remove the battery.
      Ask FixBot
Kevin Nguyen
159 Reputation
1 Guide authored
Baylor, Team 5-6, Williams Fall 2016 Member of Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 29
All Time: 861
