Up to 20% off select tools
Chromecast Power Button Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
74
All Time:
1,521
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Power buttons notoriously end up inside of devices if too much force is applied. This guide aims to replace the power button into it's desired location.
    1. Chromecast Power Button Replacement, Case: step 1, image 1 of 1
      • Place the Google Chromecast face down (with text not showing) on a flat surface.
      • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
      Ask FixBot
    2. Chromecast Power Button Replacement: step 2, image 1 of 1
      • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
      Ask FixBot
    3. Chromecast Power Button Replacement: step 3, image 1 of 1
      • Remove the circuit board, lifting from the HDMI port.
      • The power button may become dislodged.
      Ask FixBot
    4. Chromecast Power Button Replacement: step 4, image 1 of 1
      • Pry the plastic clamp from the heatsink.
      • Do not pry too hard to avoid breaking the clamp.
      Ask FixBot
    5. Chromecast Power Button Replacement: step 5, image 1 of 2 Chromecast Power Button Replacement: step 5, image 2 of 2
      • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
      • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
      Ask FixBot
    1. Chromecast Power Button Replacement, Power Button: step 6, image 1 of 1
      • Press the plastic button from the outside of the port, pushing it inward if it is stuck.
      Ask FixBot
2 other people completed this guide.
Author
with
Cameron Heiges
688 Reputation
3 Guides authored
IUPUI, Team S5-G6, Baechle Spring 2018 Member of IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 74
All Time: 1,521
