Up to 20% off select tools
Chromecast Metal Shielding Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
78
All Time:
2,281
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If a Google Chromecast is dropped or overheated, there is a chance the internal metal shiedling may lose integrity. The external case replacement guide should be consulted prior to this guide.
    1. Chromecast Metal Shielding Replacement, Case: step 1, image 1 of 1
      • Place the Google Chromecast face down (with text not showing) on a flat surface.
      • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
      Ask FixBot
    2. Chromecast Metal Shielding Replacement: step 2, image 1 of 1
      • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
      Ask FixBot
    3. Chromecast Metal Shielding Replacement: step 3, image 1 of 1
      • Remove the circuit board, lifting from the HDMI port.
      • The power button may become dislodged.
      Ask FixBot
    4. Chromecast Metal Shielding Replacement: step 4, image 1 of 1
      • Pry the plastic clamp from the heatsink.
      • Do not pry too hard to avoid breaking the clamp.
      Ask FixBot
    5. Chromecast Metal Shielding Replacement: step 5, image 1 of 2 Chromecast Metal Shielding Replacement: step 5, image 2 of 2
      • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
      • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
      Ask FixBot
    1. Chromecast Metal Shielding Replacement, Metal Shielding: step 6, image 1 of 1
      • Pry the metal extensions from the HDMI port.
      Ask FixBot
    2. Chromecast Metal Shielding Replacement: step 7, image 1 of 1
      • Insert the plastic opening tool into the corner next to the metal extensions, prying upward.
      Ask FixBot
    3. Chromecast Metal Shielding Replacement: step 8, image 1 of 1
      • Pry the metal piece around the metal, extruding it from the internal components.
      Ask FixBot
    4. Chromecast Metal Shielding Replacement: step 9, image 1 of 1
      • Completely remove the top metal casing to expose the internal components.
      Ask FixBot
    5. Chromecast Metal Shielding Replacement: step 10, image 1 of 1
      • Pry metal extensions from the HDMI port on the posterior side of the device.
      Ask FixBot
    6. Chromecast Metal Shielding Replacement: step 11, image 1 of 1
      • Insert the plastic opening tool under the corner to pry off the metal casing from the internal components.
      Ask FixBot
    7. Chromecast Metal Shielding Replacement: step 12, image 1 of 1
      • Continue prying around the device, removing the metal piece from the internal components.
      Ask FixBot
    8. Chromecast Metal Shielding Replacement: step 13, image 1 of 1
      • Completely remove the bottom metal piece.
      Ask FixBot
2 other people completed this guide.
Author
with
Cameron Heiges
688 Reputation
3 Guides authored
IUPUI, Team S5-G6, Baechle Spring 2018 Member of IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 78
All Time: 2,281
