Up to 20% off select tools
Chromecast Case Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
74
All Time:
2,310
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If a Google Chromecast is dropped, there is a chance the case will lose integrity and crack or become deformed. When removing the case, the power button can become dislodged. Be sure to not lose this piece.
    1. Chromecast Case Replacement, Case: step 1, image 1 of 1
      • Place the Google Chromecast face down (with text not showing) on a flat surface.
      • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
      Ask FixBot
    2. Chromecast Case Replacement: step 2, image 1 of 1
      • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
      Ask FixBot
    3. Chromecast Case Replacement: step 3, image 1 of 1
      • Remove the circuit board, lifting from the HDMI port.
      • The power button may become dislodged.
      Ask FixBot
    4. Chromecast Case Replacement: step 4, image 1 of 1
      • Pry the plastic clamp from the heatsink.
      • Do not pry too hard to avoid breaking the clamp.
      Ask FixBot
    5. Chromecast Case Replacement: step 5, image 1 of 2 Chromecast Case Replacement: step 5, image 2 of 2
      • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
      • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
      Ask FixBot
5 other people completed this guide.
Author
with
Cameron Heiges
688 Reputation
3 Guides authored
IUPUI, Team S5-G6, Baechle Spring 2018 Member of IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Members
36 Guides authored
1 Guide Comment
que hacer si el pin de centro de carga se despredio como pegarlo o soldarlo?
edgar arreola - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 74
All Time: 2,310
