Up to 20% off select tools
Chromebook Pixel (2013) Back Panel Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
12
Past 30 Days:
58
All Time:
105
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the back panel of the google pixel (2013)
    1. Chromebook Pixel (2013) Back Panel Replacement, Remove the rubber pads: step 1, image 1 of 2 Chromebook Pixel (2013) Back Panel Replacement, Remove the rubber pads: step 1, image 2 of 2
      • Flip your Chromebook Pixel over onto its back
      • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
      Ask FixBot
    2. Chromebook Pixel (2013) Back Panel Replacement, Removing the bottom panel: step 2, image 1 of 3 Chromebook Pixel (2013) Back Panel Replacement, Removing the bottom panel: step 2, image 2 of 3 Chromebook Pixel (2013) Back Panel Replacement, Removing the bottom panel: step 2, image 3 of 3
      • Using a small Philips screwdriver, remove the four screws under the pads
      • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
      • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
      Ask FixBot
    3. Chromebook Pixel (2013) Back Panel Replacement, Pop it open: step 3, image 1 of 2 Chromebook Pixel (2013) Back Panel Replacement, Pop it open: step 3, image 2 of 2
      • Gently pull up from the front of the laptop and open it up like a clamshell
      Ask FixBot
    4. Chromebook Pixel (2013) Back Panel Replacement, Remove the write protect screw (IF APPLICABLE): step 4, image 1 of 2 Chromebook Pixel (2013) Back Panel Replacement, Remove the write protect screw (IF APPLICABLE): step 4, image 2 of 2
      • Locate the write protect screw
      • Remove it and you can begin flashing your BIOS!
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Don't forget to firmly press down on the rubber feet so the adhesive reseals over the screws!
🔓 Did you successfully unlock your Pixel?
If this guide helped you open your Chromebook Pixel safely and locate the write-protect screw, please scroll down and click the blue "Give the author +30 points!" button!
As an independent community author, your quick click costs nothing but deposits the full +30 reputation points directly into my profile, which will finally push me past my major site-wide milestone. Thanks for supporting open repair knowledge, and happy bios-flashing!
Shreyas vuyyuru
288 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 58
All Time: 105
